glassdoctor
TEAM FUSION
glassdoctor's Avatar
08.01.2009, 02:34 AM
What tires are you running? If you have typical 1/8 tires, they are 4.5" and with a little ballooning, you are geared for around 60mph with the 1509... way high unless you are trying to just do some speed passes. Get the 3.3 diffs in it, and drop the pinion a couple teeth. That puts you more like 40mph on the calc which is still fast for a MM/1509 but it's a lot better than 50-60mph
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
