How To Remove CA'd Tires from Rims Easily
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
How To Remove CA'd Tires from Rims Easily - 08.04.2009, 06:20 PM
The video was cut short by a minute as I was explaining more but if you have any questions just post or PM me.
http://www.youtube.com/watch?v=6nyunQ_Omh4
If the Tires Do Not Pop or Break loose easily they are not Hot enough, They should seperate really easily. Everyones oven runs a slightly different temp so use a timer and play it safe, set for 5-6 minute intervals. When you remove the tires from the oven and they are smoking,it's too hot,bump the temp down a little. To hot will allow the CA to break loose easier but you will risk tearing the tire. Use even pressure when pushing on the bead using several fingers rather than one. You'll see how little pressure I applied to the tire in order for it to break free, If you have to work at it, it's not hot enough.
I sincerely hopes this helps anyone to save some money,because the freakin' tires ain't cheap.
