zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.06.2009, 12:49 PM
Originally Posted by kazuaki View Post
Can any of you more experienced guys confirm I am understanding this correctly? Does the KV rating really affect the power of the motor and the ultimate speed I will able to reach? Or does it merely affect the gearing I use to reach that ultimate speed?
For a given motor, regardless of Kv., it's the RPM that determines the power output, for example:
1515/1Y(2200kv.) @ 4s lipo = 32560rpm
1515/2Y(1100kv.) @ 8s lipo = 32560rpm
Both will have virtually the same power output (the 2Y will have slightly more because of higher efficiency from the higher voltage), but nothing noticeable.
