Metallover
RC-Monster Spudgunner
Metallover's Avatar
08.06.2009, 02:38 PM
The pot on the servo tester works fine, it decreases when I turn the knob.
Theory with the throttle: I think it has a few levels of throttle position. All the way down is neutral, then when you push it a little it goes to "step 1" which is something around 1.68, then it goes to "step 2" as you increase throttle some which is probably either 1.69 or 7.64, and so on. It doesn't use a pot but rather different resistance switches to give a few speeds rather then a full spectrum.
So now I'll try to incorperate the pot into the mechanical throttle mecanism.
