Ryu James
Ryu James's Avatar
08.06.2009, 04:59 PM
so check it out all! i got my spur gear from the CNC today. this is the 36t and the 40t will be done tomorrow. then i will take them to another shop to get hardened. but they turned out perfect. and the motor mount is coming soon.
the 36t works perfect with the standard setup. it fits in the chassis groove for the spur and clears the chassis by about 2mm. the 40t will only require to flip the diff mounts upside down which gives the gear more height off the chassis but still will sit right perfect in the chassis groove and sit a few mm off the bottom. here are some pics of the 36t.
here is the milled area 6mm deep with 4 drilled holes for m4 screws. holes still need to be countersunk.
Photobucket
here it is mounted up:
Photobucket
Photobucket
Photobucket
Photobucket
as you can see the gear spins freely.
Photobucket
i am hoping, hoping, hoping he gets my motor mount done tomorrow!
Jammin SCRT10 Neu 1512 1y
