Thread: Scorpion packs
Papa
Papa's Avatar
01.14.2006, 10:44 AM
Originally posted by Papa
I was curius as to what limitation s there where in hooking up multiple packs in series and parallel. The following is the response from Kokam/FMA.
"The Scorpion packs were tested up to 4 in series, making an 8S pack. There should be no limit in parallel configurations, keeping in mind current limitations of the connectors and wire. The ESC and receiver wires are daisy chained through each pack to ensure the LVC works on each pack. The charging must always be done on single pack disconnected from the system. This is due to the common ground of multiple chargers shorting stuff when connected to multiple series packs at the same time.
_____________________________
Visit my Web Hangar at www.gregcovey.com/rc.htm
FMA Direct
Director of Marketing and Promotions"
:cool:
JOHNNYMAXXIMA - Did you see that the Scorpion packs could be wired up to 8S?
