Ryu James
Ryu James's Avatar
08.08.2009, 03:18 PM
Our mod 1.5 pinions use a 5mm set screw. 4mm set screws are used on the mod1 pinions. :)
Oh, and the project is looking good - I am anxious to see the finished truck. :)
after i typed that i realized that. the reason i was thinking 4mm cuz the ramp uses 6mm screws and i thought they were 5mm so then i thought the smaller ones were 4mm. but i see both a 5mm and 6mm in the stock rampage drivetrain. i ended up using 6mm on this pinion only because i had 2 set screws the right size in 6mm. i didnt have any 5mm ones.
thanks for the feedback mike. btw, i still plan to use your pinions on this. i got the 12t only in case i am having heat issues. if i can get away with running 15t or 16t believe me, i will.
Jammin SCRT10 Neu 1512 1y
