08.09.2009, 02:36 PM
A 3906 tranny, converted to single speed with the GorillaMaxx conversion, and also has an Rc4wd.com aluminium output gear (still running Mike's steel idler though). The slipper is stock 3906, only its glued & tightened down fully; I tried a 3905 slipper (modified input shaft and parts purchased form TDC57 I think it was), but the plate the slipper pads attach to is only pot metal and it cracked when tightened up a bit = chocolate teapot...
