08.10.2009, 11:04 AM
Originally Posted by Finnster View Post
The idler now has less teeth, dropping the FDR.
Interesting bit on the flux diff vs nitro pinions..
If they are only changing one gear in the tranny the case must also be different. If the idler has less teeth it will be smaller in diameter and it will need to be placed closer to the gear it meshes with in order to work correctly...
