Thread: Hydra HV 180
08.11.2009, 06:11 PM
Water cooling has been covered in a few 1/5 builds- you can run tubing from the esc to a radiator & pump, and that will cool the water & the esc as it circulates. Only issue is the water cooling setup wont be cheap or small, but it would work fine. Just need to use the special fluid that is non-conductive.
