simplechamp
simplechamp's Avatar
08.15.2009, 11:27 PM
I had been looking around for awhile to try and figure out what kind of diffs came with the V3 hybrids. Tonight I finally found that they are made by Caster Racing, and are the same diffs that are in Caster's new 1/8 electric buggies and truggies. The gears aren't spiral cut, but they do have a tiny bit of an arc to them, not sure what you'd call that. Are most normal diff gears cut with a slight arc in the teeth? Now I just have to find an alloy diff cup that will work with the Caster diffs and I'll be all set.
