Thread
Making a Micro T the RCM way
Metallover
RC-Monster Spudgunner
08.15.2009, 11:38 PM
It's ghetto. That's all I can say. It started out pretty good with the motor mount, then it just got really ghetto.
I'm having trouble getting the motors to sync up at startup. It just makes a sound or spins out, take your pick. I tried changing the settings, but all I can change is the battery type and brake on/off. The escs are the weak link. Maybe I can find a better esc... mamba 25? Two really cheap?
I ended up using a y adapter with the radio connectors on the controllers. I just couldn't get them to spin together with the radio. It was a 100% trim to the right and it still wasn't good enough. The Y adapter solved that issue.
Once it starts up, the thing TAKES OFF. I thought it would be controllable on 2s, but that might be an overstatement.
Back off clean wiring freaks. This is ghetto.
Metallover
Find all posts by Metallover
