Gustav
Gustav's Avatar
01.16.2006, 03:39 PM
Well yeah,but it's 'cause i'm allergic to paralleling.If you bought 4 3s1p packs it would cost the same,you still have the same no. of cells but your only running half of them at a time so you should actually get longer runtimes by not using energy carrying the others around.Those 4000mah cells are 12c constant (i think) so that's 48amps constant which may be enough but i'd like to hear other's opinions on this.If it's not then there's a reason to paralel but even so i'd rather go to a higher discharge cell like the polyquest XP 3700 16C/flightpower 3700 20C.http://www.duralitebatteries.com/batteries-esilver.html
for the extra $15 per pack.
