Rivermaxx
08.20.2009, 08:10 PM
Lower the spur gear tooth count raise the diff ratio if you can or raise the kv then run 8 or 10s lots of way to hit your goal just cost more money. I think the neu 1.5d 2650kv is the optimum engine for 6s at 59400 rpm on 6s 60000 is pushing the limit. I believe 25 tooth is the biggest rcmonster sells but there are other alternatives.
