danhfvcsd
08.21.2009, 12:49 AM
JThiessen - The shock towers i have on my savage are different to those... I'm not sure if Mike has the wrong picture there, or if FLM have changed the design on them...
On the flux and S21, I have my LST shocks mounted the same as Metal Man at the upper position, although the bottom is different - i used 2x FLM chassis spacers and a really long screw... i have the shock on the outside, followed by a spacer, followed by the susp. arm, then another spacer, and then the other side of the susp. arm (dunno if that makes sense - will need pics probably)
I bent the standard shafts on a couple extra large jumps and replaced them with the tini shafts, so it holds up well =)
