simplechamp
simplechamp's Avatar
08.23.2009, 03:07 PM
Originally Posted by sjcrss View Post
you need the gear from the traxxas CD or mod the original lower gear like Mc did. Don't forget the (1) 8X12 bearing for the one end also.
I ordered 2 of the plastic Traxxas gears that mistercrash listed (Traxxas Output Gear 33T: TRA3984X) I believe they are from the Traxxas CD. Going to get the bearing also.
EDIT: Where did you guys find the 8x12x5 bearing? I can only find 8x12x3.5, which probably would work? mistercrash are you sure it's 8x12x5?
