J57ltr
08.26.2009, 01:37 PM
We use them a lot for little drive componets, then I found out where they get their pullies made so we use them now. SDPSI is great but expensive. We use a 15 tooth .080" pitch drive pulley and a 30 tooth for our conveyor. Boring the pulley to fit a 5mm shaft is easy, but make sure you use a drill bit that MEASURES .196",most are undersized or over sized, even metric drills are this way so watch out.
Jeff
