sikeston34m
sikeston34m's Avatar
08.26.2009, 11:00 PM
The gears are small just the the regular diff, set the slipper to your tatse and it'll last a while. You wanna use 6s with 1/10 scale diff,it's gonna give sooner or later ?
I was using one with nitro for a few months befor I decided to convert it, I checked the CD and gears were ok, but leaked dry. Leaking is problematic with the silicone gasket design. Sorry I can't be of more help..
Thanks Bondo. I appreciate it.
I just want to get this "pick list" of parts together.
My setup is going to use 4S actually.
A MMM ESC and a 36-70-2000kv Medusa. I may upgrade to a larger motor later. But first I have to get this setup to be reliable.
I'm not sure If I will like the handling changes the center diff brings, since I mainly bash. I may give it a try though.
PS.....I've been running the 1/8th scale RCM diffs. Kinda disappointed they didn't hold up longer
