zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.29.2009, 12:12 PM
Well, it's not about the amps that a person cares about, we have had enough amps for a few years now... it's the voltage under load which matters, that is what gives you your punch, and top end power/torque, be it in a aircraft, or surface vehicle. On the other hand, we are pretty close to having all the power we can use now anyways, for instance, a pack like a HP G3, or TP 40C will hold over 3.7v/cell at quite large loads for a good portion of the discharge.
I have read on some forums that the cell manufacturer is for SMC is exclusive, SMC only. So I would like forum member on RCGroups 'everydayflyer' to review these things.
