08.29.2009, 10:24 PM
Looks like this ESC was thrown together by a 10 year old. But if it performs and is reliable then if you wanted, you could make a custom case for it if you so desired.
I have to agree. Well, the seperate boards look ok, but what's with the crappy foam spacers? Poor design IMO.
And the metal case does little to help cooling. It's attached to the heatsink, but that is the only contact it makes, and even so, it's too thin to be of much use if mounted on a metal chassis.
The power board looks similar to a HobbyWing, but the brains are certainly different.
