zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.30.2009, 01:42 AM
Yah, stick with single motor setup, the truck will not even be able to handle twin CC/Neu's, especially when running twin 6s, 5000 packs... heavy.
You don't need that big of a pack, really, a 6s, 4200mah pack should provide you with the power that is needed, but, a 5000mah or larger will get you a point or two on the top speed.
Get a 1521 Neu, very powerful.
BTW, with a 1512/3D(1700kv.) on 6s, 4200mah G3 pack, Revo can hit 75+mph top speed, would be higher with proper setup as well. But, going from 75mph to 90+mph would take twice as much power, give or take. The setup was sucking just over 1000watts, IIRC.
