DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
08.30.2009, 11:04 PM
Originally Posted by Rivermaxx View Post
Dwight have you tried those kershaw plastic pinion gears. Because I am not satisfied they will handle the torque. Bigger gears can handle more torque with out stripping because more teeth are engaged that why the bigger plastic spur usually hold up. I was also told by Nic case to use steel gears but maybe a mod 1 gear is alot tougher than a 32 pitch because of the thicker gears. You guys think a real neu 1515 1.5 d ,castle neu 1515 1y or 2 castle 1512 1y with 2 esc's on 6S each would be better in a slightly heavier gmaxx for high speed setup. Dwight didnt you have a twin brushless revo ?
i don't have any of the kershaw oversided pinions but there's a guy who runs alot down at our speed place that does. his is run on a 1515 1.5D with no issues at all.
I did run a twin neu 2200 MMM e-maxx, but it was far too much torque for the transmission. i turned 2 sets of diffs and 2 3905 transmissions to dust trying the twin combo.
in order to make it work, you'd need buggy diffs all around and a center diff.....even then, i think it would be very taxing on the drivetrain.
the 1515 1Y's i ran in my e-maxx were good for over 75mph most days with the right gearing and tires. it also had good temps. i could run nearly a whole 6S 8000mah pack without getting too hot.
personally, i think the 1.5D is too high a KV motor for the e-maxx for long running times on 6S. is it faster than the 1Y? yes, but for far less time imo. mine was good for 3-7 high speed passes before i had to let it cool.
if you're going for a speed record, and wanna go for broke i might go for the 1521 1D on 5S or 6S. on the same note, if you wanted a higher voltage setup, i might go with the 1521 1.5D on 8S or even a 1521 1Y on 10S using a MGM or phoenix HV-110. but i wouldn't recommend any of these setups for everyday running.
imo, the neu 1515 1Y is your best bet for an everyday high speed motor.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
