Rivermaxx
08.31.2009, 12:19 AM
As far as going for broke I would like to keep my build on a budjet. I also would like to use an off the shelf castle mmm esc on 6s. As far as making high speed passes I only can get one good run in probably 1000' of space. So I really dont need to run multiple passes. I have UE 1/8 scale diffs and I am sure my g-maxx will weigh less than a brevo. As far as the twin 2200 turning the tranny to dust Thats why I was thinking of running 2 less torquey castle 2650 mmm combos. So running 2 systems on 6s will work then with no sync problems?. I assume you geared it too the sky right? I will put the titanium gears set I have in If I need too. So the drive train I am not worried about. Tires I am getting some custom made ones from bsr put on 23mm wheels hex wheels. I am going to do my initial testing with the 15151y first and then step up to what will work.
