zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.31.2009, 12:14 PM
Comparing what a G3 35C and a TP 40C pack can do... these should be able to do 25C discharge @ 3.7/cell, probably more.
6C charging should be expected as the 40C packs can do 5C, however, it does not benefit you to charge with that setting as it only gets you a minute or two off the charge time, 3-4C charging is optimal, after that, the pay back is minimal.
