Rivermaxx
08.31.2009, 03:37 PM
How big of gears do you guys want?
Go to sdp.si.com and go to "Buy Online". Click on the Metric Unit button. Then go down to the option for Gears. Then click on Spur Gears, next click on the suboption called "Metal". Then you should be able to adjust the search functions for 5mm bore and Mod1 specs and voila! Metal gears in Carbon steel, 2024 Aluminum alloy, 303 Stainless Steel. Teeth numbers available: 14,15,16,18,20,22,24,30,36,42,48,54,60,72,84,96.
Id be interested in the 30 and possibly the 36 but I am not sure what the "pressure angle degrees" means. It says only 20* is the only one availiable . Now looking at my spur it says 14.5* so I am not sure it will work with my spur gears.Anybody know if they are compatible? It also looks like they sell the same plastic gears up to 28 tooth that kershaw sells. sdpi sells them for less money also but I dont know what the shipping would be.
