Rivermaxx
09.01.2009, 01:06 AM
Originally Posted by speedracer1129 View Post
I don't know where you are getting pressure angle info from?? All I can tell you is that the 24t and 25t came from Mike and the gears mesh perfectly between them. I normally used a Revo 36t for a spur gear and it is the same mesh.
A mod1 is a mod1 is a mod1.........
I assume those are the same gears are from sdp.si.com for about $8 each.Alsothe same ones KD uses and sells for ~$10. The only plastic or metal gears they sell are 20* pressure angle. Mod 1 has 3 different pressure angles and they are not supposed to be used with each other, At least thats what this link says. Not my info I am just relaying it. read it for yourself. http://shopswarf.orconhosting.net.nz/spur.html
" Three spur gear tooth forms are generally used with pressure angles of 14½, 20, and 25 degrees. The 14½ degree tooth form is being replaced and made obsolete by the 20 and 25 degree forms. Figure 1. illustrates these three pressure angles as applied to a gear rack with all teeth being the same depth.
The larger pressure angle makes teeth with a much larger base, which makes these teeth much stronger
and also allows the production of gears with fewer teeth. Any two gears in mesh with each other must be
of the same pressure angle.
When gear tooth measurements are to be made with gear tooth calipers, the chordal tooth thickness and
the chordal addendum must be calculated."
The revo is 14.5 * and your gears are 20* They may fit each other because the revo gear has smaller teeth but it isnt exactly right like it should be. So a mod 1 is not a mod1 is not a mod 1. Sorry but these are the facts.
