09.01.2009, 09:43 PM
Weirdness, I was looking at axle extension like that yesterday..
Assuming all 1/8 stuff uses 8mm stub axles, then those should work fine for adding 15mm of offset basically- remove the stock items, replace with those = job done.
I found loads of different brands, some which had different length adaptors for the fronts and rears to give more offset at the rear compared to the front, just depends how much or little you want to add really, and which color you prefer :)
