Originally Posted by brushlessboy16
1515 1y and 2d
running the 2d in a buggy, 4s lipo, geared 12/48 and its temping at 160.. cant get it to cool off.
As magman said, Delta winds work best at low timing
A 1/8th buggy on 4S and 2050kv motor should be geared around 16/46 with low timing
12/48 is very low gearing and most likely the reason you are seeing high motor temps.
Gear the buggy closer to 16/46 with low timing and you should see your motor temps come down.
