09.04.2009, 01:31 AM
the higher voltage cell in the pack will stop charging at 4.2v. if it gets over 4.23, disconnect it from the charger immediately, but if it stays at 4.21 or less, it's all good. 4.22 is even ok as the voltage will drop to 4.2 after charging. if it does go above 4.23, which i doubt it will, the charger is likely defective.
