SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
09.04.2009, 02:13 AM
Try using the highest timing possible when running novak type motors on the MM esc. There is about a 30 degree timing advance in the sensors so that is where you should shoot for.
I tested the rpm of my novak hv 7.5 on the Mamba Monster and the HV-Maxx esc. Unloaded kv on the MMM was about 2550 at zero degrees timing and 2600 with 10 degrees. On the hv-maxx, unloaded kv was around 2900.
Area 52 Ranch Raceway
T.R.C.R.
