Urgeoner
Urgeoner's Avatar
09.06.2009, 02:10 PM
I wanted to use the bearing that fits around the steel end of the diff case so yes. I shimmed a bit much initially and it wasnt that strong so I JB'd it up.
I also used a bit of the 3/4" black plastic spacer found on the regular fixed output shaft. You can see it in the first picture, it helps with the end play by further reinforcing the output shaft.
