Cain
09.07.2009, 12:33 PM
A thought on keeping the inside cleaner, since people use pieces of lexan to act like shields for the rear driveshafts, it could be possible to do the same for the electronics, say from between the ESC and servo back to the motor? I am thinking something like this:
motor ESC | servo
__________|
Where the lines are the lexan. You could even bolt the lexan underneath part of the servo motor and the motor mount depending on how you bend it, depending on high the lexan shield is, you could make it tall enough that the force of the body coming down on it could hold it down, or rig something like a little lip for some servo tape.
