J57ltr
09.07.2009, 03:10 PM
It will probably hold on the end bell, but if it let go on the front it might hold for a little while. When I got my Faegiao the end bell was already popping off. My biggest problem was that the front one came off in a nasty crash. After that was when I decided to use screws to hold it in place. After checking it while bashing I noticed the motor was "loose" so I took it back apart and used a dremel with the wire wheel to clean it then reattached everything and added the green sleeve retaining compound. (there are several Green compounds most are low strength threadlockers). Let us know how it stands up.
Jeff
