TexasSP
Something, anything, nothing
TexasSP's Avatar
09.10.2009, 04:02 PM
Originally Posted by J57ltr View Post
Actually you can put a car engine in an airplane I have seen it done on.
http://www.sccoa.com/forums/showthre...light=airplane
I have even seen Wankle engines in homebuilts. The Lycoming and Contential engines are glorified VW engines (except the heads do not come off, you slide the entire "Jug" off).
My point was more to illustrate that it's not a simple drop in where as buying the proper setup will be the better and less expensive route in the long run. Not too mention that you really need to stick with the type engine the plane was designed around.
www.cubicle101.com
