J57ltr
09.10.2009, 11:32 PM
Originally Posted by Snipin_Willy View Post
Zenith Aircraft Co. has organized workshops in Florida that really push a builder to building this plane in a minimal amount of time. From beginning to finish they had one put together and flying in less than 7 days. That's a really accelerated program with experienced aircraft builders guilding 1 individual on the build. A normal person can have the kit done in about 250 to 300 hours total build time. That being said, I'm not building the plane for a hobby, I'm building it because I wanna fly it! If things go well I'll have it finished in less than a year, be even better if I can have the frame put together by sometime this coming spring. I'm not going put in a few hours on weekends, I'm going to put in a few hours every day I can manage to focus after work, and longer build times on weekends.
I'm not a person to cut corners or say something is "good enough" when it will be holding my butt up more than 2000ft off the ground. If I can understand a step in the build, I'll stop and call Zenith for help. That might be one of the first things I end up doing because I'm a little confused on installing the leading edge fuel tanks (exact place where my dad stopped on the build).
I'll post pics when I pick up parts of the kit and finish build steps along the way. Today I managed to build my work table that I'll be using, only took a few hours.
I don't know if you read in the other thread link I posted but my Dad always said "you can't pull it over on the side of a cloud to fix it". So ya, it's gotta work. I was always scared of working on aircraft because of the responsibility. If I screw up in my job I don't have to worry about dealing with a mistake that could kill people.
I remember one time my Dad came home from work and was so pissed, he had spent 4 hours searching for a 9/16" wrench, on a heli he was working on that I had borrowed from his tool bag and didn't return in time. I guess thats why he's the cheif inspector for customs air interdiction branch here.
So do you have a T hanger or a big garage you are going to do the final assembly? Can't wait to see the updates.
I'm just going to stick with the magneto driven reciprocating engines. The Jabiru should do fine and there is plenty of documentation on it.
Amen to that!!
Jeff
