big greg
09.12.2009, 07:03 PM
hes getting an overheating problem. you need to get yourself some arctic silver. 8 5mm screws and 16 washers, clean the old thermal paste off(lighter fluid i found works great!) take off the stupid x clamps. apply the new paste and bolt the heatsinks down, 2 washers under the heatsink usually works great, those "chips" that he put pennies on dont get hot, its all about the gpu and cpu that is causing the errors. after you re-attach the heatsinks unplug the fan and let it get the 2 red rings, then you will be golden, ive fixed more then a couple this way
