scarletboa
scarletboa's Avatar
09.17.2009, 12:54 AM
my KB45-8XL separated the rotor from the shaft, so i ground down the shaft on my KB45-12L 1400kv motor and threw it on my savage. the run lasted about 6 inches as my EZrun 150a smoked itself....the only setting i changed on it was turning the LVC off. i was using a lipo monitor that plugged into the balance lead on the lipos, because the stock setting of 3.0v was too low. i had done it manually as i didn't have the program card at that point and i might have messed something up in the programming in the process of turning the lvc off.
BTW: i was running 2 3s packs in series.
