Rivermaxx
09.17.2009, 06:59 PM
That chassis came out well before the UE setbacks came out and obviously the longer wheelbase with setback definatly will make it better . Another example of improvement UE products has made to the industry. Harold he going to convert it too brushless so I dont think gearing should be a problem anymore. Wrong about the diffs though 8 spiders are definatly alot stronger than 6 spiders, Robin has done extensive testing with both and has gotten 6 spiders to fail where he has never had 8 spider fail at all. The 6 spiders are strong enough for the normal rc'er though. The severe abuse he put them through is really not normal but it did prove they can fail. He also did testing with the limited slip screw gear diffs ofna had/ has out and they fail rather quickly. Chad did you buy the vbs off lito?
