plaviblue
plaviblue's Avatar
09.19.2009, 09:52 AM
Originally Posted by Trike View Post
I'm running 6s with the punch control set to 100% and reduced the throttle curve. I've broken 5 rear diff pinions. I made sure they were shimmed properly each time I replaced it.
I now have the CEN diffs in there. I took it out for the first time a couple weeks ago and somehow managed to crack the rear bulkhead where the pinion comes out. I wasn't even driving it hard. The rear pinion completely tore through the bulkhead. Both gears were fine when I took it apart.
I got the bulkhead replaced and figured the damage was a fluke. Last Saturday, It was holding up great. I was driving fairly recklessly doing backflips off of jumps and had some bad landings that would've broke the stock pinion right away. At the end of the day, I did a standing backflip off a curb and heard something crack. After it landed, I heard the click from the rear diff. I'm pretty sure the pinion lost a tooth. I saw exactly what happened though. When I did the backflip, I saw the rear wheels hit the curb and that's when I heard the crack. I haven't torn it apart it to see the damage, but chances are the pinion broke a tooth.
Everytime I broke a stock one, It was from doing a backflip and landed hard. I always let off the throttle when i'm doing the backflips, but maybe i'm not letting off early enough.
The CEN gears seem to be significantly stronger, but not quite "bullet proof" yet. Then again, I am driving it harder than I probably should.
Hopefully HPI's new diff will be much better.
Amen to that brother, In the last year I have EXPLODED a total of 44 spider gears in my FLM savage!! NO this is not a exaderation(11times x 4gears).
Everything is shimmed and built correctly. The truck weighs 18.5 pounds and has a NEU 1521 2d motor on six cells so torque is incredible. Have not tried the CEN diffs yet but the Flux mod does not help. Have been working with Jamie from FLM to try and fix the problem and no luck.
So I hope to god they have this fixed.
FLM Extended Savage -Nue 1521 2d MMMv3 6cell
E-Maxx -Flm Parts stock motors (the wife's)
Slash -MM medusa 3300k 3cell 68 mph!
[B]Custom FLM Axial Crawler
Losi Rammunition 1/184600k
