simplechamp
simplechamp's Avatar
09.19.2009, 11:28 PM
Originally Posted by 88gtanotchback View Post
A few questions i have tho since im fresh to this electric business is this.
1) why is it that when i charge one of my packs one cell is only 4.05v and the other is at 4.2 (it will climb higher then that if i dont shut it down but i stop the charge at 4.2v. I tried taking the pack down buy putting it into "storage mode" then recharged it tonight and still got those numbers. its on balance charge too. The other pack charged up to 4.2V on each cell perfectly. stayed balanced the whole time. i just want to make sure nothing is going to go wrong to cause big troubles. thanks guys and i look forward to scouring your forums for knowledge.
That sounds like your pack possibly has a bad cell. Everyone seems to be suggesting the charger is the problem, but if it can balance your other pack to 4.2v on both cells then it sounds like the charger is fine.
Keep and eye on the cells, especially the one that isn't holding a charge (check all the cells with a digital multimeter). If the one cell stays at 4.05v and won't charge any higher then you most likely have a bad cell. Not much you can do to fix a bad cell unfortunately.
I run the same 30C 2s hardcase Zippy lipos as you and they are great. The only issue with buying from HC is service and support. It doesn't make sense to send anything back to them for repair/replacement. By the time you pay for the shipping you're better off buying a new pack.
