09.21.2009, 08:51 AM
Apparently 15 tooth is the smallest pinion with the T8's stock. Smaller and the Motor fins hit the diff outdrive.
I think its down to 13T if you file down the fins.
Most seem to be using a lower Kv motor and gearing up a bit.
Also heard 4mm motor screws require enlarging the motor mount slots.
DJ from ofna also recommends putting a foam block under the rear of the motor to stop it bending the motor mount on heavy landings. Check out 'ofna live'.
I think thats right from memory. All info from surfing here, RC Tech thread and Ofna.
Cheers!
