Originally Posted by DonovanP
I stripped my 13T pinion and now nobody in South Africa have stock..I know this sucks..SO is there any way to maybe modify a clutch bell to work or something?All my other off roads not running so need to get the truggy up and running before the weekend.
Let me know if possible.I have a lathe to make a adapter or whatever is needed..
It's me again
. Yes there is . I used to have a modified mugen cluch bell pinion before hardend pinions were avalible. Mine was made by a member here named griffin . From what he told me there was a little bit of work involved in making one . First he has to cut the gear of the clutch bell . which can be tough because of the hardened clutch bell . Then he maid a stainless steel adapter . He then pressed them together with some type of industrial adhesive . It would be cheaper to just buy a hardened pinion.
