01.22.2006, 12:55 PM
i would recommend the g2r revo conversion if you plan to race alot with it and be competitive. the wanderer xl motors are the way to go for max runtime with great power and torque. the 9xl on 14 cells would give you over 20 minutes with good cells. i would recommend the ib4200s and if you can afford them i would go with matched sets. i wouldnt go crazy and spend 80 bucks on 1 pack but 50 is reasonable for a matched or zapped set. i think you should be able to get around 35 minutes on 14 cells and 9xl with good ib 4200s. coolhandcountry runs a 9xl on 18 gp 3700s and gets about 25-30 minutes of hard running.
would you mind sharing how your running a center diff with front and rear brakes in the revo tranny? i assume you have the center diff off ebay which is the same thing i have but i would really like to have rear brakes.
