jacobsjo87
09.23.2009, 04:29 PM
Did you have any issue with the radio tray? I have the same set up and when I went to bolt the radio tray in the loop that goes around the servo was contacting the front center shaft. It is because the center diff is raised a slight amount from the conversion. I'm just curious if you had the same problem.
