Electric Dave
09.23.2009, 06:56 PM
Originally Posted by jacobsjo87 View Post
Did you have any issue with the radio tray? I have the same set up and when I went to bolt the radio tray in the loop that goes around the servo was contacting the front center shaft. It is because the center diff is raised a slight amount from the conversion. I'm just curious if you had the same problem.
Yep, I had the same issue. After the first run I hit it with the dremmel and it no longer rubs.
