09.24.2009, 01:15 AM
I think the Spektrum Rxs can handle up to 9V
Now that you mention.. yeah I think it was 9.6 even, but what about the Futaba owner who tries to use one of the JR servos at 8.4.......
so i went and picked up the castle bec pro good for up to 12s and 20 amps, which is very high amps for bec i am told. anyway, all my fans are 6v. i do have 12v fans too but currently my build makes use of 6v fans. my servos are the hpi sfl-30mg 1/5 size for steering and for brake i have available a futaba s9157 and a jr9100hvt. the jr is capable of using 7.4v input but the steering servo can only go up to 6v so i will probabaly use the fut s9157 as it is rated at 425oz at 6v and the jr is 403oz at 6v.
is it possible to run 7.4v to one servo and just 6v to the other?
The HV servos were born from the rock crawler crowd, and they generally power the servo directly off a 2s lipo pack and use a BEC to give 6v to the rest of the electronics.
So, if you run a 2s receiver pack you could power your HV servo and then use your new BEC to power everything else. (BEC paralleled to the HV servo off the 2s)
To directly power the HV servo just run the + and -of the receiver plug directly to thhe 2s pack. Run the third wire (the signal wire) in the receiver plug to the receiver like normal.
