Mystro
09.25.2009, 07:08 AM
Pictures don't work.
I have solved the problem by using a mount i previously made. It's a beefy version of the RCM mount. Just need to fix a small problem with the mount and clean it up.
I also have the problem with the pinion coming off the shaft all the time. I have put loctite on the grub screw and will test it tomorrow.
Any other ideas if loctite doesn't work?
