squeeforever
squeeforever's Avatar
01.22.2006, 08:25 PM
the reason that it is lighter if you use 4 shocks is because of the shock lever thingys. without those it is lighter + the fact that there would only be 4 shocks. so basically its 4 grams heavier with 8 shocks and levers so its lighter than stock with 4 shocks and levers. so actually it would make it lighter if you use 4 shocks over stock with 4 shocks. sure hope this makes since :p
