01.22.2006, 09:17 PM
Really? I've never seen a BL ESC with the regenerative braking feature listed. Maybe Mike can confirm (not that I don't believe you Squee...). I thought it was only a brushed ESC feature. You are right though; if it did have regenerative braking, it would increase runtime. But, if the ESC simply attempts to lock the rotors when braking, that would definitely decrease runtime.
I just looked at my Nitro Revo with the 40T spur on it and there is about 1/16" clearance between the teeth and the chassis. Maybe shimming the tranny up a tad might gain a little more clearance, but not too much or the center shafts will run into the underneath of the chassis. Normally, I wouldn't care about cutting a little trough into the chassis so a bigger spur will clear, but the cut would be right on the angle and I don't want to do anything that would compromise the structural integrity.
Does anyone know of, or can measure, the diameter of a 51T Mod1 spur? The Trx 40T spur is exactly 42mm in diameter from tip of tooth to tip of tooth. Plus, using the stock spur allows the use of the stock slipper, which seems to hold up well even with larger Nitro engines. Can the 52T spur use the stock slipper assembly?
Speaking of spurs; I am using a 40T spur and a 12T clutch bell (pinion), which equates to a 3.33 ratio. When using a 51T Mod1 spur, using a 15T pinion comes out to the same ratio. If not, 14T or less should be available. Keep in mind that the standard gears of 38T spur and 15T pinion (ratio of 2.533) gives a top speed of approx 45mph at an engine speed of 50k rpm (approx). My Nitro (stock 2.5R engine) with 40T/12T gives about 30mph top speed, which is fine, so I would guess a similar 3.33 ratio would work since that engine rpm is about the same as a BL motor (actually a bit less). Here is the gear ratio chart for a Revo:
