01.23.2006, 11:07 AM
Originally Posted by starscream
I use the mgt 46t mod1 gear and a 20t/22t pinion with my maxcim setup. I am also using the center diff I got from ebay along with rear brakes :cool:
I'll have to post pics of the rear brakes when I can. Its a simple design really. I also use a micro servo for braking. I've found that rear brakes really don't require a large servo.
I am also using my tmaxx tranny on my G2R. I am working on mounting a center diff in it as well.
46T and 20T?! That's a 2.3:1 ratio. I'd like to see a picture of the spur/slipper assembly if you have one. Are you using the stock slipper, or something else? Also, did you have to cut into the chassis a little for the spur to fit? How do you have your brakes set up since they are disc?
I'm not going to be racing (at least not competitively) so just the stock braking setup will be fine for me.
